Solution Deployment error
Mirjam Schuke
Mirjam Schuke Administrator
edited September 2024 in General
This question was raised by a user and might be relevant to other community members.
What can I do to resolve a Solution Deployment error? BTW I also have a "Data Discovery Pipeline" space in this destination environment, also with the same external label but this one doesn't get rejected ...
Could it be because object have been added to the "Data Discovery Pipeline" via solution deployment before, whereas for "Reusable Workflow Space" we've always been using Synchronize?
I have a  Reusable workflow witch uses a view from another space.
  • Mirjam Schuke
    Solutions is intended to deploy a single environment to a clean environment (or at least one that does not have the same objects already created). You should not be mixing it up with syncs unless you are careful not to include the same objects.
    Solutions has to keep track of all the objects it deploys so having them created by something else is a red flag, hence the rejection.
