Remove duplicates
M.Lambert
M.Lambert Contributor
Hi there,
Just want to check with you smart people what is the best way to remove duplicates from a list. Basically I am having a problem that some data is duplicating when coming to aperture from the Azure Data Lake and while we resolve this issue I wanted to create a function to deal with this duplicates so I can do the duplicate step and run the daily automation normally.
TIA
Mariana
