Comparison Step has Limitation on Number of columns?
Map to target step to rename and reorder columns to ensure same schema:
https://docs.experianaperture.io/data-quality/hosted-aperture-data-studio/data-studio-objects/workflows/#map-to-target~workflow-stepsCan also use Transform step to rename and reorder when it is a small number of columns
I am using 2 sources 1 having 132 columns and one having 362 columns, and in Comparison step only getting 52 columns? So is there any limitation on the number of columns?
I think I got the issue , its because I dont have exact same column name in both source , Is there a way I can update the Column name in one of my instance so that it matches the other instance or I can map the column name of Source 2 with Source 1 . I am here looking for getting the comparison of 132 columns which is my Source 2 in the picture which has less number of columns. the columns in Source 2 is the Subset of source 1 but some columns not having the exact same name in Source 1 as Source 2 which is the issue here
is there any Bu on this comparison step? In the below example the comparison step giving the result that the value does not match even though its same. I observed this issue on the Numbers
There is no extra space with the numbers I copied both the values in excel and compared
"Equals - the values pass if they match. Can be configured to become non-strict equals, e.g. Ignore case."
