Assign latest changed id to all linked records
I have a scenario where input file is providing changed address ids in from-address and to_address columns. Need to identify the links between the records using these 2 fields and assign latest id to all the linked records.
Input:
event_date,from_address_id,to_address_id
20210223,120,160
20210402,120,160
20180602,110,120
20170109,200,260
20170104,105,110
20210714,100,100
20151027,100,125
Output should have -
address_id = from_address_id/to_address_id.
event_date = latest event_date of the address_id
latest_address_id = latest to_address_id from set of address changes
Below should be output for sample input records given above.
address_id,event_date,latest_address_id
160,20210402,160
120,20210402,160
110,20180602,160
105,20170104,160
260,20170109,260
200,20170109,260
125,20151027,100
100,20210714,100
Can anyone help to derive the logic in Aperture.
You want to use the same source twice, manipulate the columns then Union to combine/stack the to_ and from_ columns
Then Lookup the event_date and from_address against the original data to return the last to_address:
[Edit] Realised you also want the latest date for each id, which you could do by adding a second Definition to the Lookup step. Might be able to do this in fewer steps, but hopefully this helps
Hi josh,
Thanks for the response.
Earlier, I can able to create records for all ids with latest event_date by using columns-to-rows and group by functions.
Now tried for latest_address_id for each address_id as you suggested above but i don't get the desired output.
After union , i tried with below lookup details,
I ended up with below result
Can you please let me know the output from lookup and merge and hide columns
OK I had another look at your output and what you are trying to achieve. (Unsure how you would get the example penultimate row but ignoring that) I think you should Group to find the latest date then lookup the to_ value that matches the from AND date. Rename columns and Union the outputs
To clarify the use case again, consider below records from the example
event_date, from_id → to_id
20210223,120 -> 160
20210402,120 -> 160
20180602,110 -> 120
20170104,105 -> 110In above example, each records is linked with previous record. Latest record is observed on 20210402 and to_id in that record is 160.
So 160 should be assigned to all the ids. I don't see this is covered up in the implementation you given. Can you please check into it.0 -
I can able to get the latest_id upto 2 levels of changes by multiple joins between from_id and to_ids. But there might be many links and difficult to assign latest id to all the linked Ids.
In above result, I achieved to assign 160 for 2 changes from latest event to old event (120 →160, 110 → 120). But to get for 105 (change from 105 → 110), again i need to traverse to 2nd record (id=120) and get the latest id).
Any suggestions.
