Previous Row value
Hello,
How to tap into previous row values?
If [CurrentRow] == NULL then [CurrentRow]=[CurrentRow-1]
Like when you double click in Excel to fill empty row values with current value until next one?
thank you
These should help, (but if not can you provide an example of what the data looks like now and what you want it to look like)
You can use [Current Row - 1] along with the Get cell function to get the value from a given row and col:
You'll need to handle the case where Current row = 1 (I'd do this with an If Then Else) to avoid an error where the Get cell applies to an invalid row:
Thanks Henry, this is great! Exactly what I was after.
Now … how do I make it to loop through all the empty rows ..
this produces:
This is the Input:
It looks like you're trying to fill in blank values in the "name" column with the last populated value (which may be from several rows above)?
There's a trick for doing this:
1. In a Transform, create a copy of the Name column (using the "Duplicate" button):
2. In your function, use the copy column in the Get Cell:
This should give you what you need.
Worked like a charm! Thank you Henry!
