How to add certificates has changed
Asked by @Rfaas
Is there any online documentation available that describes the changes to the Settings > Communication screen where before my latest upgrade (went from 2.11.12 to 2.13.8)? I used to type in the server certificate details, path based on where I put the certificate file on the server. Now with the new 2.13.8 upgrade, the dialog is no longer text box for path on the server itself, but rather it is browse feature that allows upload from current workstation that the browser is running on. I have questions about this, one of which is, where will the file go if I upload it? Also, is there a configuration file that will begin to use this path, replacing the path that I used to enter manually?
Hi Rfaas
This is the documentation page that talks about certificates . To answer your last 2 questions.
- The file will not be stored anywhere - the contents will be read and it will be imported into Data Studio's secure key/trust store.
- Data Studio's trust/key stores are in a fixed location and there is no option to change it.
I hope this helps.
