Function details through the API?
Is it possible to get a list of functions via the API, similar to how the List Datasets call works (or even space-by space if an environment wide option is not possible)? Unless I'm misunderstanding the documentation, only the sharing details are exposed?
Mike
Hi Mike,
You are correct in saying that currently you can only Share Functions with Spaces via the API.
If you add this to the Ideas board the Product team will review and comment - would be good to give some info about your use-case (assume it's something to do with documenting your re-usable functions?)
You also might be interested in commenting/voting on this Idea - I think it covers many of the administrator related ideas/requests you have had in the past.
Hope this helps!
Dan
3 -
Can vote and comment here:
