Workflow Names along with Space Name
The Exportable Objects Operations API list all exportable objects in a Space. You would need to do this for each Space and then extract only Workflows from the response.
@Josh Boxer We have 50+ spaces now, then it becomes very difficult to do 50+ responses like that. Is that something planned in future to provide a GET API to extract Workflows from All SPACE.
There are no plans for it. You could add it here and see if there is support for the request
If you can focus more on the problem you are having? Why do you want a list of Workflows across your Spaces? What are you going to do with the list? (which might have a different solution than the API)0
