Job execution details to capture column mappings
Emilia Fuks
Contributor
Some of our workflows, when ran using difference sources (for different clients), will have different column mappings at job execution vs workflow definition. Could this be displayed as part of the Job Execution Details? We require functionality like this to report on what column mappings and parameter values have been used for a job execution.
6
In addition to the above, the job execution details should also capture workflow parameter values used at execution used in the re-usable workflows, which are part of the job (not only the parent job).
