Aperture Data Studio 2.12.8, Find Duplicates 3.9.1
HussainSyed
HussainSyed Member
We upgraded today our prod servers, and now we have the same situation, settings in find duplicates .ini file get overwritten and experianmatch start storing everything in C.
we changed the Ini file settings to D drive, and after that we have to rename the duplicate store to get it stored in D drive again.
we don t want to do that.
Summary:
Virtual Machine Parameters=-Dlogging.config=log4j2.xml -Dspring.config.name=find_duplicates -Dmatch.database.path.windows="D:\ApertureDataStudio\data\experianmatch" -Dserver.port="8080" -Dmatch.maximum.cluster.size="500" -Dmatch.standardize.url=http://localhost:5000
but then after installation it changed to C:
"C:\ApertureDataStudio\data\experianmatch"
Now we changed back to D, but the thing is now we need to rename duplicate store to make this work,
if this happens for next morning schedules, we have huge task of renaming duplicate stores for so many workflows and this is not good.
does experian have a solution for that?
@Ian Hayden your input would be helpful there.
Br,
HS
  • Ian Hayden
    @HussainSyed Please revert your path back as we did previously. We have installer updates being worked on right now, and this is one of the bugs we are fixing. They should be released in the next few weeks.
    Regards,
    Ian
