Grouping with TOTALS row?
FYI, my current workaround is to send the data from the grouping and perform another sum grouping on all of the columns (not the first column of data point. I then perform a union of those two grouped datasets and this gives me what i want. But was hoping for something a bit easier / built-in. thanks
Hi James
You are correct, a Group then Union is how I would achieve this:
- Group
- Delete default 'Count' aggregate and add a new aggregate
- Select 'Multiple' and set Name to blank
- Select all (numeric) columns
- set Aggregate to Sum and apply
—> Then Union this with the existing data
Optional, but depending on what you are doing with these totals, you could format / style the totals rows using a Transform before the Union. Example comma separating these likely large numbers and coloring the totals row to make it stand out:
SetCellStyle(
_RegexReplace(value, '(?:^|\G)(\d{1,3})(?=(\d{3})+(?:.\d+)?$)', '$1,', false),
'Success'
)1 -
I wish the cell style would persist when exporting to Excel - would be nice to keep the colours.
- 9 Get started
- 424 Get involved
- 2 Support
- 237 Resources
- 2 Events
- 7 Ideas and roadmap
- 310 Community categories
