Retrieving Datasets from an external system using API
Marco_13112001
Good morning,
We are currently on the beginnings of a project where we need to retrieve data from an external system using API. We have develop an small script (see below) but I would like to get some advise before running it, the idea is to collect the datasets from the external system an import them to a Aperture space
import requests
import json
# Credentials for Zendesk API
zendesk_email = "your_zendesk_email"
zendesk_password = "your_zendesk_password"
zendesk_url = "https://your_zendesk_url"
# Credentials for Aperture Data Studio API
aperture_url = "https://your_aperture_url"
aperture_token = "your_aperture_token"
# Get the list of datasets from Zendesk
zendesk_datasets = requests.get(f"{zendesk_url}/api/v2/tickets.json", auth=(zendesk_email, zendesk_password))
# Iterate through the datasets and upload them to Aperture Data Studio
for dataset in zendesk_datasets.json():
dataset_name = dataset["id"]
dataset_data = requests.get(f"{zendesk_url}/api/v2/tickets/{dataset_name}.json", auth=(zendesk_email, zendesk_password))
# Upload the dataset to Aperture Data Studio
requests.post(f"{aperture_url}/api/v1/spaces/default/datasets", json={"name": dataset_name, "data": dataset_data.content})
    Hi Marco
    The API you mention 'spaces/default/datasets' will list the existing APIs. There is a /create endpoint, but it is looking for a CSV so you would need to transform the zendesk api output or use their CSV exports
    You could build a custom step to request data from a 3rd party API https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/extend-data-studio-functionality/use-the-sdk/
    It is difficult to give further help without really understanding what you are trying to achieve. Zendesk seems to have a few different options to extract data, so unclear why you have settled on API.
    Interested to know what you are doing with the data once it is in Data Studio? If you have not already done so I would suggest manually extracting and uploading data then building out the Workflows etc as the first step
