Want to pass certain input from API to the workflow
abhishek mishra
Member
i am trying to call an API from an external website
my agenda is to pass some IDs that will be taken as input in the workflow and the workflow will run for those IDs only
and finally if i could export the result in some kind of file (csv,excel,xml)
Hi Abihishek
It is possible to call an API (using a specific ID) by building a Custom step that can be dragged into a Workflow like any other step and so end with an Export. Details on building a custom step are here including a link to github:
Speak to your Experian contact for more information
