Error while running workflow
Hello, I am trying to run the newly created workflow manually and it is giving me an error. It says source 1 and source 2 must be supplied to run the workflow. All of my source data are coming from view. Don't know what it is asking for? Does anyone know what is the error about and how to fix it?
Hi
On your source steps you have checked the box 'Can supply source when executed', which will let you switch to a new source on run,
but you have also checked the box 'Must be supplied', which means you have to supply a new source. Uncheck the box and the workflow will run successfully. Alternatively select a source:
