Refreshing Datasets Error Message
Rachael
Rachael Member
I recently updated the credentials for an external system, and when refreshing some of the tables a few of the columns have been removed. Previously this hasn't been a problem because I can just configure the tables, but since we upgraded I've been getting the following message:
Screenshot 1: Notification that there are changes
Screenshot 2: Error message which comes up
Any help would be great! The only way around it I've found so far is deleting the old dataset and adding it back in.
@SpeedySteven tagging you for info
    Hi Rachel
    What type of database is this you are connecting to?
    If you know that the columns are missing then you can 'Annotate columns' of the Dataset and set them to Optional before hitting refresh.
    We will investigate the error message you are getting
  • Hi Josh,
    It's a SQL server database. Will try that workaround for now, thanks
    Rachael
  • Ian Hayden
    Hi @Rachael, could you send me your datastudio.log file so I can look into this more. Please send to ian.hayden@experian.com and I will be in touch.
    Many thanks,
    Ian
  • Hi @Ian Hayden, just sent that over to you
    Rachael
