REST API : getting the result of a workflow in the REST api response
Hi dear community,
Would it be possible to get the workflow result in the RESt webservice call ?
In orther words we want to execute the reunning of a workflow through a rest web service, then we get in its response the result (it can be a file or a content of the report in JSONformat)
Thanks in advance for your reponse
Best regards
Ali
Hi Ali
You can execute a Workflow via an API
The Export step provides a file, which could be picked up programmatically from the location it is saved to.
OData can make a Snapshot available in another application via API
Lastly Data Studio has an SDK
which can be used to write a custom Workflow step to push data via an API in a specific format to a specific application.0 -
thank you for your response Josh,
Is it possible to create a dataset data and fill it using API
I've found somehting interresting:
section : Create a Datasetin the same link we have:
section : upload files
My question is,: can we use such api to upload a xlsx or a csv files and put it into a dataset data ?
Thanks a lot for your help
Best regards
Ali
Hi Ali
Yes you can use the Upload file API to load a CSV and get a 'fileKey' then use that value to call the Create Dataset API
"datasetName": "CSVdelete",
"externalLabel": "CSVdelete",
"space": "Challenges",
"fileKey": "0d9c2127-0d11-4867-b268-4fff9fb36ebe"
}You can test this using the Swagger UI https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/extend-data-studio-functionality/use-the-rest-api/
Thank you Josh
It works
Best regards
- 487 Get involved
- 256 Resources
