A Function with two parameters is not showing up in a workflow
koti
koti Member
I created 2 parameter Re-usable function its working and showing results.
When I try to use it in Workflow its not coming in the functions list please let me know if I am missing any thing.
Welcome!
    Hi Koti
    Need more information here. Assuming you see this Function in the Function list screen in the Space you are in
    what is the output of the Function: true/false or value, etc.?
    which Workflow step(s) are you trying to use the Function in?
    If the Space where you created the function is not the same as the Space where you want to use it, you will need to publish and share the function before it's available to use.
  • koti
    koti Member
    @Josh Boxer yes in the functions list I can see them but in the workflow list of functions I could able to see
  • koti
    koti Member
    @Henry Simms I am creating the function in the same workspace and did published and tried as well still no luck.
    If its single parameter function I am able to use it (I created all functions as reusable)
    Hi Koti
    If the Function is in the Space then can you explain what the Function is returning (or share a screengrab) plus which Workflow step(s) you are trying to use the Function in? Thanks
Welcome!
