A Function with two parameters is not showing up in a workflow
Hi Koti
Need more information here. Assuming you see this Function in the Function list screen in the Space you are in
what is the output of the Function: true/false or value, etc.?
which Workflow step(s) are you trying to use the Function in?
If the Space where you created the function is not the same as the Space where you want to use it, you will need to publish and share the function before it's available to use.
@Josh Boxer yes in the functions list I can see them but in the workflow list of functions I could able to see
@Henry Simms I am creating the function in the same workspace and did published and tried as well still no luck.
If its single parameter function I am able to use it (I created all functions as reusable)
Hi Koti
If the Function is in the Space then can you explain what the Function is returning (or share a screengrab) plus which Workflow step(s) you are trying to use the Function in? Thanks
- 490 Get involved
- 257 Resources
