Admin History View
Hi Juan
If you click the user icon in top-right corner then 'Download audit report'
This data can also be extracted via API: https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/extend-data-studio-functionality/use-the-rest-api/#audit-operations
Thank you Josh, this worked. Does the audit report only keep the last 3 months?
Good question, the default is 90 days but you can amend this by editing the Environment:
