Renaming the Datasets and share to other Spaces together
- Is there a quick way to rename all the datasets together. Example wants to add some prefix to all datasets. Can we use API to do the same? Is it possible?
- Is there a way to share multiple views at the same time. I see we can select multiple views from One Space and click on Sharing but when I am going to the next Space where I shared, there I can see only one view to include not all which I selected for sharing
Hi Mahulima
We recently added the ability to multi select objects and have plans to continue building out this functionality to allow other actions. Those you have mentioned are all good ideas.
- no i cannot think of an easy/quick way to do this. How many Datasets do you need to rename?
- At the moment you can only share one View at a time in the UI, but you if have many Views to share or this is something which comes up frequently then you could look at the API: https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/extend-data-studio-functionality/use-the-rest-api/#share-and-include-views-into-spaces
