Functions
Nigel Light
Contributor
I'm working with Functions. Re:product development, it would be a really useful to be able to multi-select Functions, eg when applying Sharing, Deleting etc, rather than having to do each one individually.
Thanks (in hope and anticipation)
Nige
Nigel you will be pleased to hear that multi-select Functions should be added in the next few weeks! You will be able to delete, but other actions would need some investigation. If it is something you are doing regularly then there is an API for programmatically sharing objects: https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/extend-data-studio-functionality/use-the-rest-api/#share-functions-with-spaces
One step ahead of me... thanks Josh👍️
