Is there an function to identify extra spaces between words?
Marco_13112001
I would like to check if is there any out of box solution for identification of extra spaces between words.
    HI @Marco_13112001 . If you just wanted to remove repeating whitespace, the Compact Spaces function should do the job. For just flagging multiple whitespace characters between words I would consider the Matches Expression function using a Regular Expression to identify the patterns you're interested in.
  • Danny Roden
    Danny Roden Administrator
    Hi @Marco_13112001, I was recently doing something similar and used the following regular expression [ ]{2,}
    The above function matches to any occurrences of 2+ space characters in succession and replaces with a single space.
    You can also easily tweak this to match to another character too, for example the comma character, by changing the expression to [,]{2,} which is handy for (in my case) finding empty values in a list within a cell (and then converting them to a comma to effectively remove them)
    You can also easily tweak this expression to match to exactly 'n' occurrences of a character, by removing the comma from within the {curly brackets} e.g. [,]{10} find any examples of exactly 10 consecutive space characters
