I want a column to only accept 'A, 'B', 'C' or 'D' as the correct values.
Hello
Automatic: 1) 'Explore' the data 2) 'Profile' the column (can right click the column header for a single column) 3) 'Suggest validation rules' for the profiled columns
4) Apply and it will create a workflow with a Validate step containing the chosen rules
Manual:
1) add a Validate step to your workflow
2) create a new rule (Function)
3) use the 'Equals' function, select the column name as Input then enter 'A' as comparison, use the '+' to add the other 3 comparison values
Equals - Checks the input value for equality with the comparison value(s), based solely on appearance (i.e. ignoring any differences in data type).
- 491 Get involved
- 258 Resources
