Is anyone doing Change Data Discovery in Aperture?
Charles Thomas
Member
In Pandora, detecting changes in different versions of source data was relatively simple - one added some sort of hash to a record, saved the result as a table and then compared the two versions. But I cannot see a straightforward way to do something similar in Aperture.
Also, is it possible to use e.g. Oracle data logs to detect changes?
Many thanks,
Charles
Hi Charles,
We got from Experian a workflow step "Compare Two Datasources", which compares two tables with similar structure - don't know how public or official it is, but helps us a lot. I use this to compare previous and current versions.
Juha
Thanks Juha, If it is standard it will help.
Best wishes
- 491 Get involved
- 258 Resources
