Calculating the difference between values on separate days
Gaz Maw
Gaz Maw Member
I have created a grouped output which counts the number of loans per day as below.
How do I calculate the difference between the number of loans each day? i.e. the difference between 16th and 17th Aug would be 35 .. and so on for each subsequent day?
I can’t find any examples or functions that do this.
  • Gaz Maw
    Gaz Maw Member
    Thanks Josh, this really helped.
    Apologies for the delay in responding. Your help is much appreciated.
    Hi Gaz
    You could try something like this it uses Current Row (to get the row number) then Subtract one = previous row
    Get cell function will get the cell relative to the current one, so in this case: previous row, same column
    Subtract one value from the other:
    Note since there is no row zero the first cell will show as invalid. You could use If then else function to set than as blank if required.
    if you wanted to do this by date rather than cell/row position
    Transform to add a new_date that Subtracts 1 from the date in created_date
    Lookup the value in that same row as new_date
    Subtract the lookup column value from your count column value
