Error with resuable workflow step in new workflow
beth.kirbybeth.kirby Learner
edited August 25 in General discussion
I have created a workflow that produces an output and has been made reuseable. This workflow is then used as the start of a second workflow and previously the second workflow has run correctly. However now the second workflow is causing errors and when i click to see output of the first workflow within the second workflow I get the error ''could not find column', despite the fact that the output runs when you view output in the first workflow.
  • beth.kirbybeth.kirby Learner
    Accepted Answer
    I have resolved this. The data source had changed slightly so by removing the output step on the previous workflow and then readding it so the metadata is refreshed.
