How to Capture Trend of the DQ Scores
I have rules created and I have scheduled the rules to run on every weekend. Now how can I capture the trend Suppose in week 1 my DQ Score for rule 1 is 65 %, wk 2 Data cleansing is done and DQ score increased to 70% wk 3 it is 75% how can I capture this trend in the graphical format?
Hi
Add a Snapshot step at the end of your Workflow. Select Multi-Batch as you want to add (rather than overwrite) data to this dataset each time you run the workflow. Once the snapshot dataset has generated some data you can use it as the source of a Chart to trend over time.
If you view this recent post by @Clinton Jones he has helpfully created a short video covering these steps in more detail:
