Parameters for Source Step in Aperture Data Studio Workflow
Hi Team,
We want to use the API to run a workflow iteratively using different source datasets (we have thousands to profile), We can't see from the documentation (either Swagger or at docs.experianaperture.io) how to define the input for the Source Step as a variable.
We've tried setting a workflow parameter, but this doesn't work. We have thousands of tables and need to automate a lot of our work. Is it possible? In Data Quality User Documentation, it says Yes, but it doesn't explain how.
Thanks for your time.
Best Regards,
Nate
  • Sueann SeeSueann See Administrator
    edited May 2021
    What version are you on? The ability to execute workflow using different source datasets is only recently released at 2.3.10. You have to upgrade to this version to use it.
  • Hi @Sueann See, I have upgraded Aperture Data Studio to 2.3.10, Could I ask for a live demo about this?
  • Josh BoxerJosh Boxer Administrator
    edited May 2021
    Hi Nathaniel
    "We can't see from the documentation (either Swagger or at docs.experianaperture.io) how to define the input for the Source Step as a variable"
    In the workflow, click the menu on the Source step and give the step an External label.
    (image included)
    @Nathaniel I'll send you a pm with regards to the live demo.
