XML driver for Aperture
Does anybody on the forum know if it is possible to read semi-structured XML data into Aperture?
If so, how do we do this? (and is it 'out of the box'?)
Nige
Data Studio has the concept of Custom Parsers, and the JSON parser is included as an example of this. XML parsing follows a similar process, but there isn't an parser which is included to do this.
Others may have created a custom parser to handle XML though.
Thanks Akshay - are there any plans to develop one in the future for future releases?
@Pavan Rao can connect you with Jacky Lu within the UK services team that have an XML parsing custom step that they have developed as custom. I am not sure how easy/difficult it would be for them to adapt it to your needs @Nigel Light
@DTAconsulting I'll get Doug to reach out to you
Thanks Clinton - I'm not on this at the moment (just a question that somebody had last Autumn)
- 485 Get involved
